lou3500
Fla. Cuda Guy
The radiator in my 66 Cuda was pretty wasted [not leaking] but on it's last legs I noticed how awful it looked when I removed it for a water pump change [which was a pain finding the right pump for an ac car]. I ordered a Champion 1635 [due to the inlet and outlet on the proper side. I just installed it yesterday [got it in October] could not use my stock fan or shroud so I installed dual 10 inch. electric fans [I recommend 9 inch fans 10 inchers are slightly tight offset]. I had to modify the mounting brackets to fit [the way I was mounting it] and redrill new holes for the radiator and the a/c condenser, everything worked out good and the car is finally running much cooler than it ever has. My 2 complaints with Champion radiators was it was warped about an inch corner to corner and I was worried it would crack when I tightened it down but luckily it did not [as of yet] and there was fin damage [not horrible] but damage just the same which I straightened best I could. I had to notch my radiator support to do my install [see photos] and trim the bottom of the drivers side mount bracket to match the curved area in the radiator support.
