.............Do u have tin intake gaskets or the composite 1s....tin will not work with 360 ports...kim.......
I thing thats a good idea!!! pull all 8 plug out and stab then through a card board box, in order of the way they came out. and then take a pic or a couple of pic's of them.
They sure don't look oily to me, a little rich maybe but looks like its firing.
the ohm reading look ok but some one mentioned that the wire could be rubbing some were. Thats a A Good Idea! give them a good look.
That list looks good. you need to keep going back to it, it will remind you what still need to be checked.
lets see all them plugs:coffee2:
Thank you....WarningThis member is trying to work through his problems so please stop the snide comments that have nothing to do with the issues.
Yes i made sure theyre all gapped to .035. Unfortunately, i dont have another holley style carburetor to test out. I did try putting electronic in, but it didnt work. I am using old parts to convert to electronic so i think something may be bad. I followed very closely the directions on how to convert. I even had a relative come over who does electrical work for a trade.kinda hard to tell from the pic, are all the plugs gaped 0.35? do you have a known good one you could use? also I'd ditch the points and drop a electronic dist. in, because it looks like your getting more fuel then spark.
Yep i definitely checked. Whats ironic is with the original 273 there were big pecans in the intake runners. Not even kidding. :cheers:If it was a booster leak, then why is number 1 lean?
If an intake leak, then why 1&4 ?
Maybe it is the intake cracked.
You checked for tennis balls in the runners right? :-D
Ok i will try this. What will opening the points do?Open the points.... doesn't matter measurement,, just open them a few thou..
2184 3657
Heres all 8. Im anxious so i did it this morning before work lol.
I am 10000000% sure that i agree with this picture lol. #2 and #8 have a misfire. All wires go to this chart. This is the same image i actually use every time i replace wires just to be on the safe side. Ill try opening the gap slightly tonight after work and i will post my outcome. What should i be looking for when i do that? What should the motor do?Look at this pic,, that was posted before (post 111, cudafever I believe),, is your #1 cylinder in the same position,, and do the wires follow a similar path in the SAME order??
After each plug was removed, i immediately put them in the cardboard and wrote what cylinder it came out of. Im not too sure what you mean by timing on the proper cylinder bank?are you timing on the proper cylinder bank? if the plugs came out as they are placed on cardboard, you are not.
