Fully Tubbed A Bodies
QuintinMotorCompany
Georgia Vermont
I am looking for pics of fully tubbed a bodies.
I heard that you have the get rid of the trunk hinges? is that correct?
Thanks any pics or Information will help
Done a couple of A bodies...
71 Dart...took out the trunk hinges...and got a pin on fiberglass deck lid..
71 Duster...the hinges are still there....so...your choice..
:happy1:
If that dont make a statement then I dont know what would....royal bad *** in the 1st degree
All depends on the tire and stance you plan on having. If you want 32" or larger and the car to be low, I think you'll need to address the hinges. Most do that by removing the weight of the factory deck and hinges and using Zues fasteners and a pin on lid. You can reduce a significant amount of weight that way.
Mmmm tubbed!
I saw this and absolutely love it. Wish it was mine!
Man--I'm telling you,There just is NOTHING that screams bad *** Mopar more than a early A body with a back end like that !!!!!!! SWEEEEEEEEEEEEET
Here you go
Here is what we done. We made new hinges where it would clear the tubs, but we keep the stock mounting points on the body and we were able to keep the stock torsion rods. You could modify your stock hinges and achieve the same thing. This car is running 345/30-19 on the back and has a 4 1/2 inch ride height.
