will 17x11 wheel fit between my frame rail and body...
jw97neon
utah
So I am going crazy here and thinking about ordering the new wheels for the dart. I did not bust out a tape measure but when looking in the rear tire well I noticed the frame rail looks close to the fender by that it appears maybe I do not have room to fit a 17x11 wheel in there. What is the widest wheel you can put early a body? I am tubing the car. Thanks
It would probably fit fine with a 12.5" tire section width or less and the right rim backspacing. I have an early A that is tubed and there is about 13.5" between the body and rear frame.
ok. I will measure it later. I just could not stop thinking about it. I am at work now so it makes it tough not to think about it. The wheels I have chosen to go with, are a 2 piece forged. Built to my spec.
I have an early A dart as well that I mini tubbed. I have just under 14" inches for tires. Make sure you measure and pick the correct backspacing when choosing your wheels. There are some great instruction on weld wheels website as to how to measure so you get it right the first time. Post some pics onc eyou get your wheels.
Best of luck.
Rod
Here is 18x12 fitting with stock framerails and rolled lips.
Max runs a 17x10.5 with a 315/35-17 on his '65 Barracuda: http://www.forabodiesonly.com/mopar/showthread.php?t=212666
He moved the inner wheelhousings in, but not all the way. You could ping him and ask him how much he thinks would fit if the inner wheel housings were actually flush to the frame.
I run a 17" x 11" wheel and a 390/40R17 tire with room to spare.
