Remflex Header Gaskets on a 340
JTG
Anyone using Remflex header gaskets on their 340 with power steering. My concern is the driver side header sits so close to the power steering gear with no room to spare, and these gaskets are thicker then the regular ones, so does this cause any issue after install with the header in relation to the power steering gear.
I'm running Remflex and it does make it closer, but clears.
I think it's worth it for the gasket quality because it sure would be a PIA to change.
I had them on my 340 with headers in my dart.
They looked like they sealed like crazy, but due to a timing chain problem i had to remove the exhaust, so i never seen if they leaked or not.
I have a busted off stud on the back of one of the heads and they still sealed great.
The heads are going to get changed out for milled 360's but the Remflex gaskets are everything they say they are.
