[WANTED] 1970-'80 1-barrel air cleaner housing for my '75 Dart.
Batesy
Fairfield, Ohio
WANTED: 1970-'80 1-barrel air cleaner housing for my '75 Dart. Need one with working snorkel door/actuator that holds vacuum, plain straight-down fitting for the hot air flex duct (not the side-entry one for rear-pointing snorkel), and without the 5/8" hose nipple sticking down from the main body for air injection.
70sublime340 - I sent you a PM
rumblefish360 - It's a Holley 1945 - not sure of the openings diameter.
pics
Thanks for posting pics. This one is designed for pulse-air aspirator-type air injection system which I do not have. Sorry but I have to pass. I had another one just like this one offered to me today as well.
Is this the one you are looking for?
It could be. The air temperature diaphragm has been capped off so that is a concern. I need that to work properly. If you hook a vacuum tester to that nipple you should get vacuum and the air temp door inside the snorkel should open up. There should be a thermostat inside the pan. I do not want it if it has a housing that has a biggish (about 5/8") hose fitting sticking down from the bottom of the housing, located in the "crown" section of the housing floor between the carb throat and the air filter element -- those are for cars equipped with the pulse-air aspirator-type air injection system.
So if you could message me or post a few more pics that would be helpful. Also, as I said in the first post, it has to have a functioning diaphragm that opens the snorkel door when vacuum is applied. Thanks
