Gauge out of tune ?Mine do seem low then, I wonder why? and why would they all be so consistently low? (besides the 99 psi one).
that was a pretty good seat of the pants / good ear diagnosis . Gauge proved you rightWell I just finished doing the compression test and like I thought, I have a lame cylinder
1- 135 PSI
2- 134 PSI
3- 134 PSI
4- 99 PSI! I squirted some oil in and it went up a bit to 112 PSI
5- 133 PSI
6- 139 PSI
7- 131 PSI
8- 131 PSI
Number 4 is the issue here. Now because the PSI went up a bit does that mean its the piston ring? I assume its normal for a bit of blowby to occur. I will try to get a leakdown tester to see what is leaking though.
Edelbrock quality comes down to the guy who cares. I know many drivers that can't tell if the engine's skipping or not - then you have Vadar here that can hear the single weak cylinder...lol. If they get bolted on and they don't fail abd break something, and the engine runs as expected by the driver, were they bad? Case in point - my truck's engine has wrist pin noise. I've been driving it like that for almost 10 years now. I know what it is, but if i were to give it to someone they'd say the engine has a knock and stop driving it. Same engine - two different levels of knowledge and acceptance. Personally I've checked a few and they all had issues I would not consider acceptible. So all of them get valve jobs and milled now. I don't have to check - I want the best I can get for my money.
In terms of the compression test - what pistons are in it? What were the rings gapped at? 135psi may be fine, but the lower one obviously has a problem of some kind.
If they're adjustable rockers,, back off both of those cylinder's pushrods till loose,, and recheck,, if pressure comes up,, was poorly adjusted rocker...
I do have adjustable rocker arms, but I also have a hydraulic cam so I wouldn't think that it would be holding open the valve, but its possible I wil maybe run another test.
Sounds like you might have cross threaded the compression tester... You can get spark plug hole repair kits - it's best to do that off the car by the way. Otherwise you can get most of the aluminum out, but you won't get all of it.
You set the gaps right at least by what you said.
Did the engine have any detonation issues? Could you hear any pinging at all? Did you pick up a load of fuel from somewhere you haven't bought before or some no-name mini-mart brand?
Noise in the carb could be a variety of thigns. I wouldn't call it important but keep it in mind when you take it apart. You definately should pull that head.
Does this engine have adjustable rockers? IMO, you never finished diagnosing it. You just ripped it apart. Did you not read my post about how to do proper diagnosis? You could have easily put air into that cylinder and found the problem. Now you cannot. I will never understand why people make things so incredibly difficult on themselves.
okay so I think I found part of the problem. Somehow the spark plug threads got stripped, I don't really know how that happened but I want to fix that .
