[SOLD] 1968 Plymouth Barracuda Drag
Wademetzinger
Member
Catoosa, ok
1968 Plymouth Barracuda Drag Car 4-link with wishbone and diagonal bar, Disc brake on all 4 corners, coil overs on all 4 corners, tons of good quality parts used to build car.
Will certify 8.50 but need to replace door bar, currently has 1 1/2" and needs to be 1 5/8" so inexpensive and easy fix to certify. (verified by very good chassis fabricator at Tulsa Mopar race this weekend)
Car only has 20 passes on it since built.
Car only weighs 1,710lbs (weighed this weekend on certified scales at Tulsa Raceway Park)
Car has been 7.90 in 1/4 with 605" Keith Black injected Hemi, motor already sold, now selling car. (not a project car that never has been down the track)
Mark Williams:
· MW 4.10 Gears (Richmond Pro Gears)
· MW Billet caps for Dana
· MW Lightweight spool
· MWBillet 1350 yoke
· MW 40 spline axles
· MW housing ends with take the bigger 3.150 bearings
· MW disc brakes
· MW 4” driveshaft with 1350 PG slip yoke for PowerGlide
· 4 link
· Diagonal bar
· Wish bone
Other Rear end components
· 66” Pro Stock Wheelie bars from Jerry Bickel
· Removable Parachute mount from Jerry Bickel
· Deist Parachute
· Dual adjustable Coil over shocks
· Not sure what year/kind of Dana housing it is but it has a drain plug on the bottom that was cast/factory, so it wasn’t added on
Front end:
· Strange disc brakes with slotted rotors
· Koni coil over shocks
· Tubular upper control arms
· Pinto Rack-n-pinion steering
· Mid plate
· Motor plate
· Aluminum Radiator with electric fan
Wheels:
· Front 15x4 on 4.5” Weld Aluma-Stars ($900 new)
· Rear 15x15 or 16 on 5” Crager Pro Racing Wheels, look just like Aluma-Stars ($900 new) (5 on 5” bolt pattern)
· MT 33x16.5 slicks
Interior:
· Autometer oil and water temp gauges
· Removable Steering wheel
· Painless Wiring switch box
· B&M Pro Ratchet shifter for P/G
· Padded aluminum racing seat
Trunk:
· Aluminum sealed battery box
· Mount for 5 gallon fuel cell
· 16v PowerMaster battery
· 16v TurboStart battery Charger
Exterior
· Fiberglass Doors
· Removable Fiberglass 1 piece front end (has a few places then need minor repair, have pictures)
· Fiberglass bumpers, new not installed but included
· Lightweight fiberglass cowl hood, needs repaired, hole cut out for bird catcher scoop
· Lexan windshield and side glass, original back glass
· Fiberglass deck with 12” wing
· Stretched Fenders to accommodate 33x17 slicks (well done fabrication)
$8,000 (pretty firm as it's priced to sell, worth much more)
Located near Tulsa, OK
2nd set of pictures
3rd set
Have seen your add on outher sites. Do you have any of the orignal body acessories such as head and tail lamps , dash and chrome. I would like to run N/SS class and would need these and outher items to convert it to the circuit rules. Also it what condition is the body
can't tell in primer
Yes. It is still for sale. I have about 12 people interested (calling with questions, etc) but no cash in hand yet.
I do not have any of the trim, that one reason Im only asking $8,000 and not a lot more. As a drag only car it's fine but like for what you want to do and what I would like to make it look complete and finished you'd need to find/replace trim and head/tail light buckets. It comes with fiberglass bumpers so that will help clean the front and rear up a lot.
Body is in good shape, doors are perfect, there are a couple of small things that need to be fixed on the fiberglass front end but simple for body/fiberglass guy and the rear fender stretches are nicely done. The doors and front end need to adjusted for door gaps, etc but that's typical of fiberglass. I don't see any rust so even with those items above I would say the body is in good shape.
Here the picture of the 3 things that need to be fixed on the front end.
Guys, I looked this car over real well.
Alot of car for the money here!
Everything well thought out & assembled correctly.
No way you could duplicate this for twice the money.
Only concern that I see was a couple of fiberglass issues, but nothing major.
Very easy fix.
I wish it had been available when I bought the Barracuda I have now.
Would have bought it in a heartbeat!
I would be running 9's instead of low 10's.
