straightlinespeed
Sometimes I pretend to be normal
My 71 Scamp came with the LBJ's on it. I wanted to add a sway bar so I found some LCA's with the 72 down brackets on the outter edge of the arm. Since that is the K-member I have. I swapped my spindles so that the disc's are now in the back, so those would not hit the sway bar. Well I have a different issue.
The front bolt that holds the lower ball joint onto the spindle hits the tabs for the sway bar. So much so that I only got about half the turning radius that I had before. I guess Im curious if others have had this issue? If so what did you do to fix this?
