Since I've already introduced myself in the Welcome Wagon, let's go into project right away.
https://farm3.staticflickr.com/2896/14398577968_99f3a0e7b7_c.jpg
I've done almost a full C-body resto project and wanted now something that does not have
to be original and something with performance and attitude. This '71 Duster just happened
to come available and I did not think more than 2 days and went and bought it
The car is without the engine and transmission.
It took a few days to arrange the transportation for the car, but now it is home and I have
been able to do some investigation on it. Fender tag says following:
VL29:
Plymouth Valiant,Duster
Low
2 Door Sports Hardtop
G1E: 318 230HP 1-2BBL 8 CYL
1971
Los Angeles, CA, USA
104397: Sequence number
E44: 318 cid 2 barrel V8 230hp
D31: A904 3-Speed Auto Trans.
GF3: Medium Green Metallic (Dodge), Amber Sherwood Metallic (Plymouth, Chrysler & Imperial) Exterior Color
L4F7: Trim - Low, Vinyl Split Bench Seat, Green
GF7: Dark Green Metallic (Dodge), Sherwood Green Metallic (Plymouth) Int. Door Frames
908: Build Date: September 08
042321: Order number
GF3: Medium Green Metallic (Dodge), Amber Sherwood Metallic (Plymouth, Chrysler & Imperial) Top Color
U: USA Specifications
G31: OS RH Manual Standard Mirror
G33: LH Remote Racing Mirror
N51: Maximum Engine Cooling
M25: Wide sill moldings
N95: Emissions Control
R11: Radio Solid State AM (2 Watts)
V5X: Body Side Stripes, Black
END: End of Sales Codes
The car was loaded with parts and there should have been most of that parts inside:
https://farm4.staticflickr.com/3916/14427772778_254be5ca87_c.jpg
The paint job with matt black looks OK from distant, but some weird has happened :
https://farm6.staticflickr.com/5491/14613857852_f089d30151_c.jpg
It seems that all doors, both fenders, the hood and the deck lid are not original. Could be a collided car, since the frame and body are not that rusty.
Left door, notice the door opening handle:
https://farm4.staticflickr.com/3853/14427814759_059b648e42_c.jpg
And the right door, from different year? Which one is the original for 1971?
https://farm4.staticflickr.com/3861/14468052370_0df26795dd_c.jpg
General photos:
https://farm4.staticflickr.com/3871/14427769088_746962bdf6_c.jpg
https://farm4.staticflickr.com/3898/14427768928_117524c5b8_c.jpg
We had a little accident when trying to get the car onto the trailer. The front wheels
jammed and when we pushed the car with another car, it started to move sideways and
landed on the right lower corner:
https://farm4.staticflickr.com/3878/14612328844_d7991eae18_c.jpg
Positive thing is that it seems to be solid metal under the paint
The reason for the front wheels jamming was the too big brake calibers with 13" wheels. After getting the car home, I took these away just so that I can move the car.
https://farm6.staticflickr.com/5521/14468301357_f1694f438e_c.jpg
https://farm4.staticflickr.com/3839/14631757176_cbf8a786d3_c.jpg
Even though the fender tag does not say anything about the disc brakes, the discs would
seem original? Is it because of the 318 engine? The calibers are from somewhere else, the brake lines have been cut so that the original calibers are gone and lines left. But are these similar to originals or some heavy duty calibers?
The floors are in pretty good shape. There were some small holes and someone had put coins on them??? Never seen that before. One of the previous owners had tried to do some welding (unfortunately) in the trunk, those just need to be redone:
https://farm4.staticflickr.com/3883/14591367526_63673d959c_c.jpg
https://farm4.staticflickr.com/3890/14427797649_2301ccc1f1_c.jpg
This is also a new part to me, perhaps something to do with the emission control?
https://farm3.staticflickr.com/2932/14651492161_45eeed5b8d_c.jpg
Under the rear fender there is this kind of part too, any ideas?
https://farm3.staticflickr.com/2911/14612308934_030e83ccbc_c.jpg
These seem to be some inner fender stuff, but don't know if they are from this car or from
some other?
https://farm4.staticflickr.com/3837/14614377205_2c7b9c6207_c.jpg
The lower control arm bushing is "done":
https://farm6.staticflickr.com/5515/14613856942_4d4fb80b8b_c.jpg
It would look like the control arm is already worn itself, but that remains to be seen when
I drop the whole front down. All bushings and joints will need to be replaced.
This project will take several years, don't know exactly yet what to do with it, but now it
is started. The missing parts list is long, from front lights to front seats and a lot of smaller stuff.
VL29:
Low
1971
General photos:
some other?
