440 timing pinging and popping thru exaust
73abodie don't be a smartaleck owning mopar since probably before you were born I know better than to crank on a mopar distributor but a dumb chevy guy wouldn't and yes I tried to reset it but since he turned it both ways I was not able to get it back to where it was initially set and the popping and pinging only happens under WOT...and yes I did put it under a light but what good is that without knowing just where to set this thing up at so I was wondering if anyone might have a similar setup with their 440 and could tell me what the appropriate setting was instead of snyde remarks like yours 73abodieadd
actually they were legit questions and a response. judging by your sentence structure .. well, nevermind that...
do you know how to find top dead center? that would be a good place to start. you said yourself you went "romping" on it AFTER the guy went screwy with your distributor. with all your years of experience , this shouldn't even be an issue for you, its not for me...
good luck
ok lets try and straighten this out...
1967_CUDA...nice post one of the few that were genuinely helpful...shows you actually read all of the post
MOPEKID...yes the factory 10-10 marks are there but this setup requires an initial setup of more than 10 degrees advance with NO VACUUM ADVANCE
AJFORMS...one more time ...THERE IS NO VACUUM ADVANCE...yes I wish I still had the old dist it was turned in for core value
KRAZYKUDA...I felt his post as a slight...he didnt read the post Thoroughly, and slighted me with this statement "so your "friend" moved it, and you didn't move it back , or re-time it before you went "romping" on it?" you figure out how
roccodart440 ... have you ever put in a dist in a chevy??? two very different processes since a chevy dist isn't simply either "in" or "180 out" as in mopars and I think you know what I mean when I say "either in or 180 out"
"No marks on the balancer, well Mr. old guy, that can be fixed pretty easily. Since you have been in the game for so long, I'm sure you know what to do. "
why yes young mopar guy you get a digital timing light but just what degree of advance do you set the init timing???
"Plug the vacuum advance until you have this problem solved. It shouldn't be advancing via the vacuum advance"
your not reading young mopar guy (typical) there is no vacuum advance...try harder next time
MOPER... another intelligent post...the replacement dist came from Napa auto parts and you are correct I have no idea just where the sdvance curve is with this dist or even if it is working correctly...again a digital timing light could tell me if it is functioning correctly I BELIEVE... I MAY BE WRONG
[/B]AJFORMS... do you have your answer yet or are you still waiting???
rustyratrod... "Search "Hillbilly timing tape" on the forum. Nuff said. "
get a digital timing light please go back to your rusty hulk now enuf said
73abodie... "you said yourself you went "romping" on it AFTER the guy went screwy with your distributor. with all your years of experience , this shouldn't even be an issue for you, its not for me..." the popping and pinging only showed up under WOT it wasn't like he turned the dist 2 inches and left it there he cranked it back and forth...I tried to reset it back to where I thought it was....under normal driving conditions it was fine...does that clarify the issue to those who might be confused??? those who do not read Thoroughly...well then you should give up posting...anywhere
and for the trolls out there yes I left 1 thing out of my posts I neglected to mention that I didn't let the chevy guy time the car he just grabbed the dist and cranked on it without my permission
You don't need a digital timing light or timing tapes using a hillbilly timing tape. It uses the std 10-0-10 marks as well. Good god damn that's convenient! Some people like to save money, count me in. Been timing cars with a 30 year old inductive timing light and HTT method, no fancy or sometimes finicky electronics required.
Good luck with it.
Figure out how the set the advance curve in the new one, and then set it properly. You're the only one that can get your hands on it.
I am assuming that once I put a digital timing light on it I can tell if the dist vacuum advance is working properly but I don't know how to tell if it is setup properly...can you tell me a brief synopsis of how I can tell if the curve is correct and how to properly adjust it or is that something best left to an expert since I have never torn down a dist just replaced them?
Just a guess, a stock distributor is going to have way too much mechanical advance in it if it's a reman from a store. You might get lucky, but I doubt it.
I wouldn't worry about vacuum advance at this point, it's the last piece of the puzzle.
Initial
Total 34-38 is usually a decent range for a BB in most cases
Curve - Springs
Vacuum
That's the way I do it.
Good luck with it.
sure but borrowing a digital timing light is even better and easier but just where do you set the init advance???its just not setting up @ 10 deg advance this particular setup needs more advance...I just don't know where...my distant memory says 17 degrees advance but I am not sure(1 year ago which was when I last worked on it it still either popped or pinged around this number, I would have worked this out by now but medical issues prevented me from it) ...and then if I do get the correct setting and it still either pops or pings what might be the secondary problem as 1967_cuda suggests?? bent pushrods???
Initial
Curve - Springs
Vacuum
sorry the word "vacuum" was a mistake
There are a lot of variables when it comes to setting timing that make it difficult to give exact numbers. Camshaft design, compression, the quality of the gas, weight of the car, etc... If we assume that your harmonic balancer is 7&1/4" in diameter (as all of the 440 ones were that I've seen) then you can make some marks on your balancer to coincide with the degrees you want to hit with the timing light.
If you use the calculator on your computer you can figure out how far from the TDC mark to scribe your new lines. Taking 7.25" times pi you will come up with a circumference of about 22.765". Dividing that number by 360 will tell you how far apart the degrees are on that balancer. It comes out to .063236111111. I know it sounds like a squirrelly number to have to deal with but just take that .063236111111 and multiply it by the number of degrees away from TDC you'd like to see your new mark.
As an example, if you wanted to mark your balancer for 34" advance it would come out to around 2&1/8". You could use masking tape and a pen rather than put a permanent scribe mark down. One nice thing about the masking tape method is that you can do your measurement on a bench. Just make a TDC line and measure away from it to where you want to draw your next line(s). You just line the TDC line on your tape with the TDC mark on your balancer. You may find that the tape method is easier to see with your timing light too.
Most builds that I've seen similar to yours don't go past 36' for total advance and it's usually all in somewhere between 2500 and 2800 RPM. It will probably take a little playing around to figure out what's best for the exact combination you have. I wouldn't suspect bent pushrods or any other major motor snafus yet. If it ran great before the distributor swap you're probably going to find the issue with your distributor. One of the nice things about a digital timing light is you have an RPM readout right in front of you as you're reading the timing. You'll be able to tell if the advance is coming in right about where you want it.
A lot of folks don't consider the initial timing to be a critical spec to hold to. They try to start with plenty of initial while trying not to get to the point where the car is difficult to crank. I've always thought of a vacuum advance more as a retard system. It kicks in as soon as the motor starts so that the timing doesn't have to be set with timing that's too advanced to want to start. The problem with factory timing specs is that they rarely are accurate for a modified motor.
and that is wherein my problem lies :banghead:
--In my experience, popping in the exhaust under closed throttle deceleration is usually caused by a combination and interplay of the following 4 factors/errors;... 1) air entering the header pipe,between the head and the collector, and 2) too much unburned fuel in the exhaust, and 3) late ignition timing, and 4) a too far open curb idle adjustment.
It usually begins with late timing.To compensate for the late timing, a guy might just crank up the idle speed. Then when the engine returns to idle from some higher rpm, a large amount of fuel gets pulled into and through the engine because of the exposed transfer port and ends up burning in the header, where the leaky pipe provides the air. Then you get the popping.
This is all avoidable with correctly setting the primary butterfly, to sync up the transfer port, and controlling the idle speed with timing and occasionally cracking the secondaries.Big cams like timing.
Your combo needs 3 things right now; More initial timing, a transfer port sync-up and elimination of the combustible mixture in the header.
The following discussion assumes either your dizzy is not equipped with a vacuum advance can, or you have defeated it and blocked the sparkport.
-It starts with giving it more initial timing and syncing the transfer port. Once this is done the third may take care of itself.There are 2 ways to do this; the best way and the easy way;
1)The best way, I know of to do this is to remove and drain the carb. Flip it over. Make sure the choke mech is disengaged.Now study the transfer slots,on the engine side of the butterflys.What you want to see is the slot form a little square, beneath the plate. Use the curb idle screw to set it. Next move to the secondary cracking screw. Set the screw in such a way that the secondaries are completely closed but not sticking closed; that is to say, just barely open.Ok, now reinstall the carb.And finally set your fuel mixture screws. They generally have an operating range of 1.5 turns out +/- 1 t. See where yours are.
2)The easy way; If you are sharp, back out the curb idle screw a bit until the engine wants to stall, then crank in a bit of timing to bring the idle speed up.You will need to do these two steps more or less simultaneously. Now gently open the butterfly by hand to be sure the transfer-ports are still working.Do this as many times as is needed, until the engine stumbles or hesitates,when gently opening the butterflys.Then crank the butterflys back open about 1/2 turn. This method is somewhat tricky, but gets you there with less mess or fuss, and if you cant get it , you can still go back to method 1.
-Now that the t-ports are synced we can move on.
-Next; if you have a Holley,lets set the float level.For all others we will assume its right---for now.
-Next lets fine tune the mixture screws. With the engine warmed up, put the idle speed up using the fast idle cam, to something like 2200rpm.If your carb doesnt have a choke you will have to use the curb idle screw. Just count the turns so you can return to the current setting. Ok, so were at 2200 ish rpm.Adjust the mix screws for best rich quality.If they dont seem to work, put them back to 1.5turns and reduce the rpm by 200 and repeat. When the engine responds, return to the previously set curb idle that you memorized.If nothing seems to make a difference, set them to 1.5 , and we will return here later.If the idle speed now is reasonable and the quality is good,we are done.From this point on, do not monkey with the curb idle screw.But if the idle speed/quality is not stable and the engine seems unhappy; we have 3 options; More timing,Cracking the secondaries, and fuel level
-Next;Lets fine tune the initial timing.As previous posters here have said, every combo is different.However, some generalizations can be made.1) the bigger the cam, the more initial. 2)If the starter kicks back, its too much.3) if when you put it in gear it wants to die, she probably wants more. OK. I think some initial numbers were thrown out there. I dont recall you mentioning your cam size, so lets just do this; Put the light on it and see where we are at. If it falls between 14 an 24 we are close.Write the number down so that if we have to, we can return to it later. If you have a vacuum gauge hook it up now.By hand, increase the rpm until the vacuum gauge settles down and gives you a maximum number, then return to idle.This is your target vacuum.Obviously changing your timing alone wont get you that number,For now, its just a target to remember.Now if your initial is on the low side of the range(14)crank in some initial and observe the vacuum reading.Keep doing that until A)the vacuum peaks, or B)the engine complains, or C) you hit the estimated max(24), or D) the idle speed gets excessive.Badaboom thats done.OH, not quite.Now you can go back and revisit the mixture screws if they didnt previously respond.
At this point the engine should be idling pretty nicely. Theres a couple of more things to do yet before we can drive it.Idle speed,Accelerator pump adjustment,Total timing, Rate of advance
-Idle speed; If the idle speed is too fast, you will have to reduce the initial timing.As a last resort for setting the idle speed if it is too fast, you can turn the speed screw out a bit. Keep track of how far you move it in case you need to return to it.If you encounter a hesitation after the adjustment,you will have to put it back. If its too slow, you will have to increase the secondary opening. And again, as a last resort you can turn the speed screw in a bit.In every case the mixture screws may require readjustment.
-Total timing;The total, all in, timing has to be limited to what the engine will accept at WOT without detonating, on the fresh fuel you are using. Numbers have been tossed out.Ive never had a BB, so cant give you a max-power number.I have heard it may be between 34 and 38 with iron,open chamber heads.With good fuel and on the street, 32* should be a safe starting point.So,Lets see where youre at.With the engine cooled off some, start it up with the timing lite at the ready.Rev it up to 3000 and read the timing.Increase to 3400, read the timing. Increase to 3800, read the timing. Repeat until the timing no longer increases, or the pistons come through the side,lol.No, No just kidding.If youve done this before, theres no need to do the indexing, just rev it up til it reaches a max number.This usually occurs before she gets to 4000. Now if this number is more than say 36*,It will have to be limited.Figure out how it needs to be done in your dist, and getrdone.
-Next will be roadtest, and finally rate of advance.
-So for the roadtest; We are at this point only concerned with full-load WOT/ no detonation, and assumes the carburetion is at least close, and the cooling system is running a decent temp. So use 2nd gear. If you hear rattle at any time, back off, increase rpm by 200 and retest. So, cruise it on up to 3600 or so and roll into WOT, listening for the tell tale rattle.With 3.55s and an auto this will be about 55 to 60 mph, so; Pick your test highway carefully.If it hasnt rattled by 4800, it likely wont and test can be concluded. If it does rattle, and then quits, take note of at what rpm. If it doesnt quit, back off the dizzy 2* and retest, until it quits.If you experience zero rattle, crank in 2 * and retest. Repeat until it rattles, the back up 2*. its probably best to not exceed 36* for now. So now its back to the pits. After a cool down period, Put the T-lite on and lets see where its at. Rev it up and read the number.This will be your max timing spec. Write it down.Finally revisit the base timing. If it has moved too far from the previously optomized number, its back to the bench with the dizzy for modding.
-Finally, the rate of advance. New roadtest. This time we are not concerned with full load WOT, but rather part-throttle roll-ons. So 1st gear will be fine. Now remember the Max timing, and the base timing now are fixed. Were not going to mess with those any more. So, from stopped, gently roll into it.No rattle is good. From stop, this time a little harder, roll on it.No rattle is good. Repeat until it rattles.If it rattles at any time, you are going to have to slow the rate of advance down. This is done by use of those pesky springs in the dizzy.You will need, depending on the dizzy, to change them out for stiffer ones, or bend a spring anchor. Then retest. Repeat as often as necessary to eliminate the rattle.Then check for rattle on roll-ons at other rpms and load settings. Change/ adjust the springs as may be necessary.
-And double finally, you will have to prove your jetting is correct.
-So there you have it.You should be able to get it pretty close in about 4 to 6 hours depending on your skill level. With practice, in chassis tuning gets faster. Most of the time is spent inside the oem dizzy. There are aftermarket types that are more tune-able.
- Now, I should tell you, Ive been at this one-finger typing, half asleep, for quite a while. So if anyone spots errors or omissions, feel free to jump in.
Ok, gotta go to work.
Im baaack.
- Now remember that target vacuum peak, we recorded earlier. Heres how that number gets to mean something. When the vacuum peaks, this is an indication that the engine is starting to become more efficient.Before this rpm, the pistons were sending some ingested air back into the intake, due to the late-closing intake valve. Now when the engine vacuum peaks its partly/mostly because the rpm has risen to a point where there is no longer time for this reversion to happen. The point is this, for best fuel economy, your cruise rpm should be at/above this number.
-And heres my take on the vacuum advance system; If your building a track car, you probably dont need one. ALL other street type cars will benefit from having a well tuned system.You will enjoy more mpgs, smoother/quieter cruising, a cooler running engine, better part-throttle response and quite possibly more part throttle torque. I cant imagine running without one.
-If you are anything at all like me, you will be fine tuning your timing for many tankfuls to optomize it. A fully adjustable vacuum advance distributor will make tuning a lot more enjoyable.I know you just bought a new dist, but it may not be the one for you.If this seems rather daunting, be advised that there are companies out there who build timing boxes that have either adjustable or selectable preset, timing curves built into them.Pricey tho.
-Now, lets see how THIS plays out.lol. All the best to you.
are you going to time your engine ? OR are you here to start trouble ?
if I were to guess, you are young and wet behind the ears. lol
because most of us OLD DUDES know how to time an engine, pretty basic! lol
START TROUBLE???? sir I think not you obviously aren't reading the entire posts or are a personal friend of the cretin troll of whom I have addressed
"if I were to guess, you are young and wet behind the ears. lol" If I were to guess you wouldn't be able to guess your way out the front door :burnout:
"because most of us OLD DUDES know how to time an engine, pretty basic! lol "
most of us old dudes do but obviously your old dude eyeballs cant read thoroughly, or maybe you just fell asleep in the middle of reading but I understand being an old dude too
Exactly. Look at post number 8. Yet he says no help. Then piles on me and everybody else for not helping. Help is what we ALL did first, before he turned it into a slug fest.
There's no one set spec for timing on something like that. You simply have to experiment with it until you get it right. If it really has that much compression, you can start at maybe 14 initial and 32 total and go from there.
a very good starting point.
You go back and look at my first response. It was the FIRST ONE to actually DO WHAT YOU ASKED and you ignored it. You ASKED for a timing setting. I gave you a place to start. No one else did up to that point.
Seems to me you're more interested in being a prick and arguing than solving your problem. You keep being an *** face. Your help here will fizzle into nothing.
actually your first post was helpful "There's no one set spec for timing on something like that. You simply have to experiment with it until you get it right. If it really has that much compression, you can start at maybe 14 initial and 32 total and go from there."
I would reset it with a light. I have seen distributors marked and moved, then moved back, and it is still not quite right.
I seem to recall a way of setting timing with a vacuum gauge. Anyone else ever hear of this method? Being as how I haven't had to do this for quite a few years, I don't recall this procedure in detail, but I am sure a google search will turn something up.
Yup. Just as everybody has figured out. You're here to cause trouble. I hope you keep chasing your tail. I am done. If yall are smart yall are too.
Again, you're insulting one of the guys that can help you figure this out.... :banghead:
He may be a little harsh, but he knows what he's talking about. Look at how many thanks he has.... :evil3:
If he was such an a--hole, he wouldn't have that many thanks... #-o
Ignore his "jabs" and give him the info that he's asking for, and he will help you out.
