leaf spring bushings ?
j par
Well-hung Member
Portland Oregon
Is that big front leaf spring bushings bolt supposed to be so darn hard to get off? And can I get new bushings at the local parts store ? Thank you . ..
Spray with WD-40 let soak in.The worn bushing,s will have to be pressed out.If a race car,go with solids.Check with Mancini,s ..JMO
Don't forget to lubricate new bushings when putting them back together, otherwise car will creak. Ask me how I know. Im redoing mine, but putting in a 3.75 at the same time so not a waste of time.:burnout: MT
I'd at least go with a poly bushing, street or strip.
