straightlinespeed
Sometimes I pretend to be normal
I took apart a spare 8-3/4 housing that had 2.76 highway gears in it. To install some 3.23's.
The yoke I pulled off the housing Im setting up was a 10 spline, and also the u-bolt style. I could not get it to fit my 7290 u-joint caps. The caps just sat at the top of the yoke. I assume, (like my old yoke) on my original housing which sadly was 29 spline that the caps should just sit in the saddles.
Does anyone know what size u joint this yoke may fit? I couldnt find any #'s on it.
My u-joint measures roughly...
End of cap to end of cap about. 3.654
Outside of clip to outside of clip. 2.670
Cap Diameter. 1.128
by my quick measurements that is a 7290 u-joint.
Cap Diameter. 1.128
