gorgerider
I've never had to deal with anything like hopping up a V8. All my experience is with stock restorations. I've done a lot of searching on this site and come up empty. I see a lot of numbers associated with cam selection and simply don't know the language. I do know there are lots of options and manufacturers.
Is there another thread or other lead which explains the numbers and can help me select a hydraulic flat tappet cam for the following build on my '64 Dart conversion (street application):
'66 273 w/ 10.5:1 pistons (bore unknown)
Eddy 600 cfm carb
Eddy SP2P intake
920 heads, ported
Stock manifolds
Single 2 3/4" exhaust
'75 A833 3-speed OD
7 1/4" rearend
Thanks for your response. GR
Eddy 600 cfm carb
Eddy SP2P intake
920 heads, ported
Stock manifolds
'75 A833 3-speed OD
7 1/4" rearend
