Anyone have old Direct Connection or Mopar Performance books or articles?
dibbons
La Paz, B.C.S., Mexico
Specifically trying to find technical information regarding the ins and outs of how the Mopar 305 was built by de-stroking the 340 back in 1970 to qualify to race in the Trans Am series against Mustangs and Camaros (and used once in a winged Dodge during a NASCAR Daytona 500). Interested in identifying the specifics of the rotating assembly (crank, rods, pistons) and cylinder heads. Or if you have a motor, I'd like to look it over. Thank you.
There was also a 305 NASCAR Hemi.
I have the Direct Connection Performance Book that goes into great detail. The short version is that there was a special 340 block produced for use in Trans Am and NASCAR that could be configured for a number of displacements. The 1970 305 used a 2.96" stroke crank. Standard 4.04" bore landed it at 304 cubic inches.
They also used the stock heads. Rules is rules. The T/A head had the off set rockers and the ports did not have the pushrod pinch in the intake valves.
I have not seen that crank for sale in a very long time.
this right out of the book , click on the pdf file.
Cheers.
  • IMG.pdf
Thanks for the race bulletin above. It mentions the part number for the 304 Trans-am crankshaft and describes it as a "full radius, forged". I wonder what is meant by "full radius"? Is that a different construction/profile from the 340/318 crankshafts?
this was at the Welborn Winged Warriors event a few months ago and man was it radical sounding
My understanding is , it was used on 426 hemi motors
and on some six pack motors , and that it was a racing
type crankshaft, being full radius made the crank stronger
and less likely to snap at the rod journals. Please note that
the drawing is not to scale or 100% accurate. LOL
It is just to give you the basic idea and difference between
a full radius crank and a undercut radius crank.
Cheers.
In case you don't have it part# P4452974 for the 2.96" crankshaft.
Maybe a google search will find one. like here-http://www.moparpartsgiant.com/parts/mopar-crank-2-96-stroke-a-eng~p4452974.html
Bob Tarozzi talks about the development of this motor in his book "Turk: The Lives I've Lived". There's a thread about it on here somewhere. He says he welcomes questions at [email protected].
MoparPartsGiant lists the 305 crankshaft, however, when contacted, the response was the item was "discontinued".
Seems like a hard part to find. And if you do $$$$$$$$!
Was that the same size as the engines that were used in the Iroc series Daytona's ? Or was it 306 ci ?
the 1990 I.R.O.C. engines were 355, 475 hp @ 6800, X block @ 4.020" x 3.48" Moldex crank, 6.125" Carillo rods, Diamond 10:1 pistons, ported MP 360 high swirl iron heads, Holley 750, Victor intake. the other 305 was used in the trans am road race cudas and challengers in 1970 + 1971
