Hi all
I am looking at installing a 360 magnum into my Abody. I already have a magnum in my other Abody car and its supercharged with a carby and goes great. So this car I am doing now will not be a super powerful car. I want it for more of a tough cruiser with over 300hp to 360 FWHP and keep the aircon etc.
As it will be more of a cruiser I am contemplating keeping the factory efi. I have done some research on this site and it looks like I can keep it efi and swap it as long as I have the factory ecu and buy a new wiring harness, efi pump and regulator.
Have I forgotten anything? Do I need anything else?
If this is all I need to do the next question is will the factory efi be ok to up the power a bit or is there a low limit I can go. The 1st magnum I ever built was 360 FWHP and all I did was swap the efi to carby, install extractors and changed to this cam. I would be very happy to have this as my cruiser but I don't know if the factory efi will allow this.
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=661&sb=0
I do have 2 of these cams. One with lobes ground at 110 for a carby and one ground at 114 for efi so I can go either way. My concern is that I spend the money keeping the factory efi but end up not being able to get my required HP because of the efi may have limitations.
Any help is appreciated.
cheers
cheers
