69 Dart turn signal problem
Easy Rider
Member
Angie, La.
.Help! Turn signals will come on like they should on both sides but they don"t blink. I figured it was the flasher since it was already flashing so slow, but I've tried 3 or 4 different ones and still won't blink. Any suggestions?
you sure you aren't changing the wrong flasher? Separate flashers for hazard and turn. "How to tell?" Easy!! Pull the flasher out and see "which" does not work
I didn't know it had 2 flashers. I only saw the one. I'll look for the other. Thanks
one is usually under by the fuse/steering wheel area held in by a clip and one under the radio area also by a clip/ I went leds and had to use a electronic relay// careful some electronic relays are sold as such but are (electro mechanical) electromagnet relay and still need some kind of (load) to trip the circuit //get a (solid state one) it will have a pig tail for a ground !!! I LOVE LEDS nice and bright with polished lenses //the amber bulbs in the front say I AM HERE!!!! and the rear say here's my A__ __ !!! as for as them staying ON bad ground /dirty bulb sockets and the bulbs aren't drawing enough current to heat the metal strip in the relay // the one linked is a (electromagnetic) use this one // this will blink with NO bulbs in there sockets !!!!
CEC Industries EF32RL Electronic Turn Signal Flasher Relay, LED Compatible (E-bay)
My 70 dart has the turn signal flasher unit was near the glovebox,don't know if the earlier Darts have it there too.
