Your using a p4120534 chrome box right?
Anyone, for the Neutral Start, can't the lead on the starter relay be jumped similar to a stick. Yeah, it would crank in any position, but just to try and isolate a problem.
Don't know if this hurts or helps. Installation points from the book ...........
Thanks for the info, but I'm confused about the part where it says to check the voltage for ignition terminals #1 and #2 with the ballast resistor disconnected... You can't get voltage to terminal 2 with the ballast disconnected as terminal 1 feeds it...
We did check for voltages with it connected and posted them above...
I also took a complete MP electronic ignition kit out of the box with a new ballast, orange box, and distributor and tested it with no better results...
I found my distributor from the MP kit is off... The rotor is 90° off the slot that drives the distributor gear...
Check this out, the rotors are pointing the same direction, but the slots are 90° off...
Now with the slots pointing the same direction, the rotors are 90° off...
Here's the date from the box...
WTF???
