Hate to break it (snicker) to y'all, but if you want ease of service and easy replacement parts, points are NOT the way to go, anymore.
Sure, modules fail, but modules are a heck of a lot easier to find and replace than points. Most chains carry modules, but points, not so much
If points were easy to find, this thread would not even exist. Without the knowledge of people on this site (which is hard to find in bfe on the side of the road), op would be at the mercy of the parts store (usually up said creek minus said paddle)
Run the oem electronic ignition for easy install, and common parts. Pertronics drops in, but I'm not so sure advance or oreilly stock parts for em. The oem module they certainly do.
Best case, install the oe electronic system, toss the points dizzy in the trunk on long trips, or wire up for oe electronic, disconnect, then run what you want aftermarket - wise, knowing your backup system is just a plug in away. Y'know, redundant systems, like aircraft.
