MC pushrod parts needed
pauls340
17 miles N of Detroit
So I really need that little rubber seal at the end of the rod. This one goes in but when I try to pull the rod out...it comes out by hand....and it shouldn't. Somebody has to sell these. Any help is appreciated. Thanks.
Once it is installed, you will have to want to dislodge it, to actually dislodge it;but it could happen I suppose, in a panic situation.
Does your M/C have the proper receiver-groove for it?
yes the MC is correct. Why can't I use the correct outside diameter rubber hose and slice it the correct width as the current seal is?
That's a pretty good idea except the hose may not last long. Now, a nylon tube would work;the kind they use in pressure systems. Or a square section O-ring cut to fit, say from an old caliper piston(do not oil it!)
I suppose your idea would work, until it got brake fluid on it.
Whatever you use, do not oil it.Use the silicon O-ring lube, if you have to.
