I totally agree. All the cars I've seen with SS springs sit higher on the passenger side rear.
What makes you think any of those cars are actually level? They're just pictures off the internet. You have no idea if they're sitting on flat ground, or if the camera angle is tricking you into thinking they're level. The first picture actually shows the car higher on the drivers side, but look at the ground that things parked on, nothing even remotely flat. In that 3rd picture with the blue car if you look at the wheels you can see that the right wheel rear is not in the same plane as the rest, that car is sitting in a hole to look level. The perspective in the 2nd picture is the only one that would actually show you if the car was level across the back, and again, just because it's parked on asphalt doesn't mean the ground is level. You need a measurement to confirm. Heck, same goes for the measurement. If the car isn't parked on flat, level ground not even the measurement means anything. The measurements on my Duster change by an 1/4" on some corners if it's parked in my driveway vs. parked on the slab in my garage. Parked on the slab it's within a 1/16" side to side. Parked in the driveway it's usually off by at least a 1/4" depending on where it's parked, how the wheels are turned etc.
