How I Made My Engine Dolly
this might give you guys some ideas.
yes! :d
What's the dimension between the 2x10's that the pan fits into? I don't have a pan handy and would like to have the dolly built for the engine when I get it home. Thanks.
Could someone please measure the distance between the two 2 x 10s for those who don't have an oil pan handy? thanks!
I just made mine over the weekend all out of 2x10s even the base. The only thing I did differently was to make it fit over my engine stand... utilizing its frame and wheels saving some space in the garage.
The wood engine dollies are great! I built 3 of them which are all in use.
One "Note" make sure you have clearance on the dolly wheels turning 360 degrees. Mounting holes location may interfere with 360 rotation.
I got this mamma-jamma with one of the early Hemis I bought in Oklahoma. It was bolted to a 354 that ran an irrigation pump.
It was just a skid but I welded on wheels to let it move easier. This will be the base of my engine run-in stand.
With the price of lumber and steel both in the stratosphere, I wonder which way would be cheaper to go?
Good thing about a project like this is it can be made from repurposed materials. I prefer steel and it's surprising what what you can get for free or very cheap. Old shelves or pallets go a long way with a little elbow grease.
pro tip, don't ever buy your steel where you buy your lumber :)
one can still find some angle iron laying about....even an old bed rail can be utilized and often had for low cost. When I installed lights beneath my lift for when I need to do other projects and one is stored above when lifted and blocking light, two sets of bed rails to the rescue....with lights, just a bit of time and less than 75.00 including the LED lights as shown.
I used a combination of bed rails and a pair of matching drilled angle iron I have had stored for 30 years...(never throw metal away) when making this engine cradle. The battery, console and gas tank portions are bed rail.
