You're welcome, after you get it set and start driving the car here's how you check to make sure you have it correct. They make (Summit/Jegs) angle shims to make minor corrections to the pinion angle:
Checking to see if you have got it correct:
If there is no vibration under normal operating conditions then the angles are correct.
If there is vibration under acceleration, you need to add more downward pinion angle preload. If the opposite occurs, the vibrations tends to decrease or disappear under acceleration, you need to reduce the downward angle preload.
If the vibration steadily increases with driveshaft speed (either accelerating or decelerating) the symptom is primarily the result of a driveshaft imbalance or yoke runout. Sometimes this yoke runout problem can be improved by rotating the U-joint 180-degrees in the rear end differential yoke.
Driveshaft-related vibrations usually occur at roughly engine speed in high gear. Wheel/axle vibrations usually occur at 1/3 rd engine speed or driveshaft speed because of the differential gearing. To determining whether it is the output of the transmission or the pinion in the differential, change gears when the noise occurs and maintain speed. If the vibration/noise changes in frequency, the source is in the transmission or engine. If the frequency remains the same it is a driveline problem.
Good Luck
Treblig
