Do you paint your engines fully assembled?
trebor75
Sweden
My 360 is apart now. When I'm finished working on it I will paint it. It got me thinking. Do you guys and gals like to paint it fully assembled or do you paint some of the parts separate? It's gonna be blue with aluminum intake and mopar performance valve covers. I think I'll do the pulleys black so those go separately. Just curious how you like to do it. I'm not sure I want to paint all the bolts blue because when you then work on it later the paint come of anyway etc.
I paint my engine components separately and then assemble. I don't like painted bolts and rarely paint all components the same color.
A lot more masking if you want to paint major assemblies separately. But there are some brackets, bolts, etc. that may want to be a different color, or that get in the way of a good spray, that you can easily do separately. IME if you don't paint the bolts they just get rusty, unless you are talking about environmentally-controlled storage, which I don't have.
I admit my last motor was rather quick & dirty...
Just finished my 340 after replacing timing chain and water pump. Did it in the car, assembled .... also did my 383 fully assembled ... Bill hirsch paint is top notch by the way ...
I paint stuff as I clean them, to prevent flash rust, then assemble.
If the whole engine is going to be one color, it will put a coat or two on after it is assembled so all the paint matches.
I pretty much just paint the block, leave the heads the aluminum color, or if iron heads paint the same as the block, but water pump and housing, intake manifolds all leave aluminum, course thinking of getting the ones for my current build Powder coated atleast the intake and front cover. Here's my big block in my 72 satellite, just left the aluminum as is.
Great looking engines you all have! Now I feel really inspired and will do it mostly assembled. I might borrow some ideas from the nice pictures you posted. Thanks!
I use vht, I did use primer on my last engine I built. Not sure if I'll use it again
done both ways they look way better out of car , especially if different colors used , and much better coverage and quality ,but there all ways a can of oops for overspray the quality will show if its done out of car or 1 part at a time , and pretty engines are like pretty cars love to see them revn 7500 or doing 300 mph sitting still out is my preferance especially when all wires and hoses out of the way , that way you get full coverage . next car I build if I get the chance spend the $ on the go fast and hookup I'm not going to worrie about car paint. GL with your choice and your build
I paint the block, pan and heads all together and then everything else separate because I like contrast.
If there's one thing for me that says 'quick & dirty' and 'taking the easy way out', then it's an engine that looks like it's been dunked in a bucket of paint.
When I see an engine painted all together with bolts and all, I start to wonder how many other easy shortcuts have been taken during the build.
For me, seperatly painted engineparts and clean bolts give a much better the appearance the builder has had some pride in his work and had an eye for detail during the build.
