Birth of the Blue Missile
Bought a similar spoiler setup for my Miata but don't have a switch. What are you using for a switch?Looking for a one touch auto up/auto down solution preferably. Link to video from prior owner.
https://photos.google.com/share/AF1...?key=ZDRDWjAtaGtpemw1X3NRT0RwMmxacWF4bms5elJn
I found another small project tucked away in a box. I resized the fender braces for the front quarters and had been holding on to the parts to create a couple of link rods for that purpose. That is done.
Go get an electric window switch, They operate on the same switching principle. I used one of the switches in my avionics switch group. You need a dpdt maintainet switch for this.
I just finished putting together a plating set up for black chrome and gold plating. Next is an interface for the TCI tranny and the paddle shifters.
Next is the TCI tranny interface. Just finished the CAD dwg and have the parts in the shop next is a hot soldering iron.
Andrew,
Awesome stuff you come up with. I wish you lived nearby I could use some electrical assistance with my FAST wiring
While waiting on the small breaks in the humidity level, so I can spray lacquer, I have been working on the Tranny /shifter interface for the Duster.
I thought I had an enclosure that would let me stand the four relays up, but that was not to be. So I had to go to plan B and lay them down. The machining is done so NOW I can fire up the soldering iron.
More later
I'm sure Andrew is out plotting his next move. He'll update eventually.
I am still here, the build is on hold until I either uncover some small project I packed away before the move, or my Son graduates college. I visit and read but I am building guitars on the cheap to keep myself busy. I do uncover the car and air it out while listening to tunes and exercising all the relays. It has a permanent on board battery charger plugged into the house. Ill be back it wont be long now!
Hiya Andrew, its been a while. I just got caught up on the Missile build, you've really done some incredible work! When I heard you talk about what you were going to put into this car, I admit I was somewhat skeptical. I really didn't believe it could be done, but your achievement so far goes beyond what I thought was possible in a home garage, or anywhere for that matter. Well done. I think last I heard you had just done a CF dash pad and brought it in to a club meeting for show and tell.
I really look forward to the time you can move forward with your drive train and paint.
I understand how long these things take though. I took apart my Challenger in 2008 and am just now getting reliable enough to drive it much. My build is here: I Finally started my 70 Challengers Gen III Restomod!!
I just picked up a Duster and am getting ready to start on it. Just collecting parts and making a plan at this point.
Chris Ryon
Chris Ryon
Are you back in Austin?
If so give me a call, I am here most times during the day, Playing blues at night. You can come see the progress, punch the buttons and have a beer
