73Swinger18
Any luck starting her up?
180 out should be producing impressive fireballs out the carb.
I learned that the hard way. When I installed my reworked engine, I installed all new components from the ballast resistor to the fuel pump. Bad idea.me thinks we may never get the resolution to this mystery, but we can learn something from this. Degreeing in the cam isn't a luxury, it's a necessity, and it goes a long way to help diagnose should problems arise later on. I like the idea someone had about taking a picture of the timing gears timing marks in the lined up position. It requires very little time, money, or effort and saves tearing back into it, if you start having doubts.
Another lesson learned should be don't introduce a bunch of unknowns on top of an unknown. Use a proven working carb on a new engine. If you want to add a new ignition system, do so after the engine is running, and the cam is broken in.
Document the engine. So you know, later, what was done to the engine, what parts were installed, and how they were installed.
73Swinger18 is right make sure no. 1 piston is tdc on compression stroke not on exhaust stroke then make sure rotor is pointing to the plug wire going to no. one cyl.I have recently rebuilt my 318 after it spun a bearing. It is a highly modified engine meant for street/strip use.
It will not start. We have spark, compression and fuel to the carburetor. It cranks and cranks but no start. Once in a while it will cough, but it's intermittent. I have put the long mark on the harmonic balancer to TDC and verified that the piston is actually at TDC on this point with a screwdriver and with the valve-cover off looking at the rocker arms. I've tried starting it from TDC with no luck. I've tried starting it ~8degrees advanced and retarded to no luck. We've always rotated the distributor all the way during these times to no avail. I am running a full MSD ignition system with a Holley 650 double pumper carb with 5.5lbs of fuel pressure to the rail.
We are unsure if gas is actually getting into the cylinders though. It's going through the carburetor because I can see the gas squirting in it, but when I pull the plugs, they're dry. However, when I pull the carburetor which is sometimes full of gas from pumping it, the intake will have a little bit of gas in it. Sidenote: The carburetor is a newly rebuilt piece with less than 600miles on it.
It still refuses to start and I've been working on it for like 3 days just on this stupid timing aspect. Does anybody have any ideas?
If the valves are opening 180 off, ............
It's a very odd situation. We just got done resetting the chain at TDC with dots at 6 and 12. I will be attempting to start it sometime today and will update.
