[FOR SALE] 68 Cuda 318 valves, 904, driveshaft
yotah1
Dearborn
As I'm rebuilding the car, i'm trying to make some space in the garage and basement, I hope the prices will be fair.
It all comes from my 68 Cuda, all was running fine.
It is all located in Royal Oak, MI 48073
Shipping can be arranged but if possible I would prefer local pick up in the Detroit area.
Prices are negotiable in a reasonable manner :)
Happy buying guys, I hope these will help someone else on their car.
Contact here or via PM first, then i can give a call.
Stock piston for a 318 engine, 4 valve recess, with pins and rings : 90$
Automatic transmission pedal assembly (with pads) + parking brake assembly : 25$
904-7.25 driveshaft 2.75"diameter 51.43"length (small U joints) : 40$
original 318 air filter : 15$
Brand new 318 stock diameter valves (1.78" - 1.5") : 150$
original 68 A-904 transmission with linkage (worked fine when i got it out, shifted great) : 150$
Fuel pump : 20$
If possible can I get a quote to 34638 Land O Lakes Florida. For the transmission thank you.
FedEx and UPS both quote around 90$ 3-day ground shipping for the 904 trans.
Fuel pump : 20$
Is the 904 transmission counsel or colum shift? Thx , 65'
Sorry i didn't see my inbox was full. It was a floor shift 904. I have the linkage that I removed from the gearbox but can include in the sale for a few bucks if you need it
I am interested in the transmission, I sent you a PM.
Valves, pistons, driveshaft are still available. Free shipping on the small items.
Were the valves installed in heads? Im curiouse because my factory manual shows 2 different valve face angles for 69 and 84. Im using 302 heads from mid 80's. Ex and Int for 84 is 45* But for 69 318 Exh is 43* and Intake is 45*.
So exhaust is slightly different.
Make/part #?
Thanks
Steve
