OK I'm hoping someone can help. 71 Demon, original s/6 now 318 with console shift and I believe this along with the steering column switched out. Old restore, whomever did this did an excellent job on the console shift short of wiring lights to it, but that's not the problem...
I've been tiring to get the horns to work. Horns work on direct 12v, wiring from horns to bulkhead is intact, green w/red , tested with volt meter, and with 12v from bulkhead connector but on the inside of the bulkhead the wire is yellow w/blk and runs to the headlight buzzer. I've been using a 71 Dart diagram for the wiring and it shows that it should be green w/red running from relay to bulkhead. I cant seem to find a diagram that shows a headlight buzzer. Here is a pic of where it runs from the bulkhead. There are 2 black wires, one black from relay and the yellow w/blk from the bulkhead. One of the black wires is connected to the Yellow w/blk but I don't know where it goes from there.
Here it is connected to the 2 wires that run to the buzzer. The buzzer is under the glove box and works correctly when the headlights are on and door open.
Here is a pic of the horn relay
I took the relay apart to clean an test. It is working properly. Press the horn and it clicks, conductivity is good thru the contact. But no horn. I cant find where the green w/red terminates. If anybody has a setup like this I'd like to know how it works. I'm guessing the other black wire tied into the yellow w/blk has something to do with this.
Also there is this
I think this is for the key buzzer but I have no idea where it goes. Its not on my diagram ether and I'm guessing its for a newer model. Nether buzzer is that important to me as I want the horn to work but I would like to have this wired properly. Any help is appreciated.
Also there is this
