glhx
looking for a roof skin for my 69 dart.
Can I use a 4 door roof skin?
I'm thinking not but I want to be sure
I have a roof skin for it already.
My roof had a vinyl top. It has holes all over the place so it's done.
The replacement also had a vinyl top and has craters but not deep.
I'll try to get some pictures
There were some holes all along the roofs side edge. Very small pin holes throughout.
Upon trying to weld them up it just made them bigger.
Come see me in Murfreesboro, I'll get you hooked up
For example......
If I were to fill in the pin holes with something like job weld or some sort of filler it would be fine.
Then run several coats of high build or feather fill. I could fill in the craters.
I was going to put a vinyl top back on so it would not have been a big deal.
I don't want to do that now so I'm looking for a better roof close to Nashville area.
Where are you at. I just moved from there a few months ago.Come see me in murfreesboro, I'll get you hooked up
I have a couple you could look at, or I can probably weld what you already have.Where are you at. I just moved from there a few months ago.
You have a roof?
