Its not everyday you have two cherry old muscle cars lined up on the street anymore! Was epic! I NEED more traction!!!!NICE!
That's not uncommon in performance converters thoughNothing wrong with the way it shifts, just converter gets tighter as it warms up.
spend the $$ on the off set shackle set up - low impact on originality of the car - then get them Keystones on there with MT street radials - it'll hook upIts not everyday you have two cherry old muscle cars lined up on the street anymore! Was epic! I NEED more traction!!!!
I think it got by the censor'soh hell - did I just post that...![]()
heat is the enemy.. that's why racers like to have as much time as possible between rounds.. let 'er cool downThat's not uncommon in performance converters though
Might just.spend the $$ on the off set shackle set up - low impact on originality of the car - then get them Keystones on there with MT street radials - it'll hook up
it'll get some attention in here - sooner or later..I think it got by the censor's![]()
and there it is!!I stepped out to water the new trees. Did I read right? Two old cherries wanting to service a tranny?![]()
Nah, the converter is too light for the application. Needs to be a 3500-3800 stall for the engine.heat is the enemy.. that's why racers like to have as much time as possible between rounds.. let 'er cool down
I have a better solutionNah, the converter is too light for the application. Needs to be a 3500-3800 stall for the engine.
oh yea - that's what - a 2500 in there right Tim?Nah, the converter is too light for the application. Needs to be a 3500-3800 stall for the engine.
You are very spendy...with someone else's money!I have a better solution
T56 swap!
the man has some grandiose ideas for sureYou are very spendy...with someone else's money!
Said the builder....oh yea - that's what - a 2500 in there right Tim?
Based on what you describe, that's probably right. 2400-2800 with heat resistance bringing it down to 2200.Said the builder....
So 3500 stall you are thinking? Hell of a lot less expensive then a T56 swap!Based on what you describe, that's probably right. 2400-2800 with heat resistance bringing it down to 2200.
3500-3800 stall should fit the bill with your engine. Get a tranny cooler too if you don't have one already.So 3500 stall you are thinking? Hell of a lot less expensive then a T56 swap!
You have a way of making things easy for me to understand! Makes total sense.Here's what happens to ATF with temp...
This is why a hot ATF temp reduces stall speed. With a much lower viscosity, the fluid flows faster and more easily causing the converter to more fully transfer the power to the output shaft at a lower rpm. Add in more engine torque and the fluid resistance drops too. That's why the same converter in a high torque engine has a lower stall speed than it does in a lower torque engine.
Yes I do . If I'd ever win the lottery, look outthe man has some grandiose ideas for sure
