Mechanical fuel pump threaded fitting size
Taconite
Active Member
Traverse City
I have a mechanical fuel pump shown below. There is a threaded outlet. I don't know the thread size. I tried 1/8" NPT a 1/4" NPT and it is not either of those. Anybody know the correct size?
IIRC it is tube size threads - not NPT. Am unsure of that size.
On stock engines there was metal tubing that ran from there up to the carb or fuel filter. As previously stated, you need a tube fitting & metal tubing. Or an adapter to go from the tube fitting to a rubber hose barb.
