Jury is in..... Holley Street Dominator vs. Factory Cast
You learn everytime you run it! Did you say you ran a 1" spacer on 1 intake and not the other? You can get a bunch out of the stock intake, but that being said I would KILL to take 30+lbs off the nose!
The factory cast had the "square bore to spread bore" aluminum spacer that's about 3/4 inch thick. The SD has a plastic 1 inch spacer so the gas line going into the carb don't hit an "unused" mount.
Grind down that unused mount and see if there is any difference between using a spacer versus none. Going to be trial and error in tuning but there could be some hidden horsepower there
I just ordered the 1/2" plastic spacer to replace the 1" I used. I'll see what that does.
Can do that with the 1/2", curious how it would react with no spacer at all. Slight differences in plenum and runner volume may affect the torque curve and where it peaks
:thumbsup:
My money, this single plane manifold,wants the 1/2 inch. Driven a couple,amazing how,responsive they are,with older action cams. Jmho,tune it...until peak.
Tune it..... until it peaks.....
Got it in the mail today...... Going to cut the size of the spacer in 1/2.
P.S. - It think it's a no-name. Bolt holes fit tight over the studs. The studs they gave with it were too short, about 3 threads out of the carb base... LOL Ebay special, gaskets, hardware, and spacer for 15 bucks free shipping :D
Bottom line is it works, just had to use different studs than what they provided
When I was using a Street Dominator on my 340, I bent both fuel feed to carb inlet tubes. My recollection is that I always ran with a 1/2 inch phenolic spacer, but maybe for a little while it had the thicker Holley insulating/spacer gasket. These were about 1/8 thick and extended under the fuel bowls. If I can find a pic, I'll add it.
I went out of town and played around a little with the new 1/2 inch spacer installed instead of the full inch. Definitely didn't hurt. Honestly, my seat of the pants (all the years.... practice makes perfect :D) is pretty good, and I just can't believe this car lost MPH. I only had the one run as the track was super packed and I didn't stay for a 2nd run. I'll be giving it another whirl..... hopefully before the season ends.
