Product Compatibility Questions
SpeedThrills
Very South Jersey
I'm getting stuff together start working on the body of my Duster clone. I bought this primer: https://www.amazon.com/gp/product/B016QO0MIS/?tag=joeychgo-20
I bought epoxy because I don't want any rust to start on this long term project. I read a book about bodywork after I bought the primer. (whoops) This one: https://www.amazon.com/dp/0760349452/?tag=joeychgo-20
The author stresses using products from the same maker, to be sure they all get along. I understand that.
Did I screw up by getting this primer? What about reducer? For that matter, what type of paint should I use? (Lacquer, enamel, urethane?) It's been 25 years since I did work like this. I think I need to learn more before I go on. Back then, lacquer was "out", enamel w/ a hardener (so it could be sanded and buffed) was in. Now I'm not sure what to use. I don't have a place to paint, other than priming and doing jambs, trunk, etc. But I want to prep with the right (compatible) stuff.
I have been buying on the web because there are no body supply stores around here. I could possibly go to the local body shop that fixed a dent in my truck and ask if he'd guide me tp the right products. -Expecting him to mark them up, of course.
This won't be of much help to you but I just want to put in my 2cents worth
I'm a house painter been one for 30 years and you're absolutely right that painting has changed alot over the years thanks to the EPA and low VOC paints.here in Ohio I can't even get oil paint except when it comes to primer however if I drive across the border to Indiana I can. it's been awhile since I painted a car but pretty sure I can't get lacquer either
In the house painting biz they have made great advances in latex paint and there's an acrylic alkyd that's almost as good as oil paint used to be emphasis on the word almost
Having said all that I think they even make water based automotive finishes now which blows my mind, but seeing that the last car I painted I used Sherwin Williams A100 satin black exterior house paint and an airless sprayer.... That was 3 years ago and it hasn't so much as chipped I guess anything is possible , I know house paint on a car? And I'm NOT suggesting that you do that but yeah sure it's a 20 footer but it's at least all one color now, and it IS a pinto
I also am no painter but from the dozens of body shops I have been in I think it is smart to buy all your materials from one supplier. Most auto paint suppliers have a cheaper line to save you money. At least all the chemicals will play well together.
Speed, is back , at it :) Did you get a PRODUCT DATA SHEET , with that primer ? IT : should give you : Recommendations on spray guns, air pressure, caps ( new,to you,and me ), reducing levels ,and ..all the goodies. IF USUING A TRUE GOOD H.V.L.P ...The normal 3/8 " inch air hose ,doesn't fit anymore. LOOK for "High flow HVLP pipe fittings " , and ask lots of questions about what you think about what you actually buy ,before you do.
Yeah, I'm back at it. It may take me a while, but I'll do this!
I meant to google the sheet before I posted here, I forgot. I'll do that and get back.
I am using a HVLP. This one: https://www.amazon.com/gp/product/B001N1E9Y8/?tag=joeychgo-20
I never would've thought I need air lines, too!
I have lots of work to do, before I even touch the car. Phewwww.
Thanks for the replies.
