Might be easier just finding a new harness than fixing that one. The alt gauge is always off don't worry about it, there is a IVR behind the dash that goes out and affects the fuel and temp gauges, that's why I asked can be that simple.
Tony @whitepunkonnitro is a good source for harnesses, there is actually a 74 dart that just showed up being parted out on the site, not to sure what interchanges though.
Just bulbs for the cluster, headlight yes there is a good thread on that also, search is you friend on this forum.
A headlight relay kit makes a world of difference in brightness, just realized you have points right? If so you need a 72 back harness, post a thread to see what will work I am not versed on them. Hey you ever check your dwell if you have points? You could have point float that is why it is sputtering at speed also. (weak spring pressure on the points)
Prob a dirty ground, 71 should be points electronic started in 71, easy to tell one wire out to the coil or a two wire with a plug.
LOL Thinkl the cabled wire is the coil wire goes to the center of the cap then two wires to a plug? Then it is electronic.
I would find a engine harness first that will get rid of a lot of it, you want a 8 cyl harness for the engine, don't think the dash makes a difference except maybe year, not positive on that except the seat belt interface. You might just have electrical issues? Mopar electronic distributors are very reliable, the control boxes do crap out but they are a easy change and usually just die. You have to watch with the one wire that it has the right curve for your engine or it can be a dog.
Put up a wanted add some one has on I bet and send tony a message also good guy and good parts. I have to run, snow removal time!
Not to get too far off topic, but:
TMI! LOLNot to get too far off topic, but:
Mine just arrived yesterday, just installed the app a few min ago.. This one slick tool! I got the 6.5mm version. Now I can do my own colonoscopy!!
