I feel the same way. As you have demonstrated, flow over squeeze.
While more compression helps, it’s not the end all.
Went from 110 octane to E85. Dealing with the corrosion I experienced in my fuel system turned me off. Then I found out I could make more horsepower with 91 octane than most people could make with race fuel. I will never build another high compression engine. It's simply not worth it, to me.
I didn't say I could make more horsepower with low octane than race fuel. I can make more power with race fuel (or E85). I said I could make more horsepower with 91 octane than most people could make with race fuel.I was talking to a fellow whose brother has a 900HP mustang running E85. I didn't get into detail about what compression he is running .. I wished I asked... but the car is EFI. I know it's doable but was interested in the pros and cons of E85.
I would like to hear the way you make more HP with low octane rather than race fuel... or is it top secret?
I think we calculated in about 11.3 to 1? I've been running a 100LL since the beginning and mostly just drag racing in the car or cruising around town. This year I plan to put it on the street more and would like to start running some pump gas through it. I know my cranking compression is down around 190 195. But my cam should have enough bleed off I think to get away with high octane pump gas. We'll see...
10.3 c.r. here , alum. heads, .037 quench. 91 dog piss is all we can get at the pump here. no pinging.Went from 110 octane to E85. Dealing with the corrosion I experienced in my fuel system turned me off. Then I found out I could make more horsepower with 91 octane than most people could make with race fuel. I will never build another high compression engine. It's simply not worth it, to me.
