I bought these..MOPAR "A" Body Torsion Bar Set, 1961-1976 - Sway-A-Way | Racing Technology
They make them in house....
I wondered this too but figured the 1.03 may not be as popular as the smaller sizes. So that might be why the 1.03 is cheaper to buy.
Those that ordered their Bilstein shocks from PST... Did you get new hardware or just the shocks?
Just a question: Do the larger diameter bars stress in any way the frame where the hex is to hold the bar from rotating? Assuming the car is not rusted......Yes. Our bars are clocked so that you can achieve a quality ride that is not harsh but firm. More so like a modern car feel.
Thanks
James
Thanks
James
I have the PST 1.03" torsion bars and the Bilstein shocks (ordered to PST as well). I believe it came with all the hardware. The only hardware I don't think it came with was the specific washers that go on the lower shock mounts for the rear.
The torsion bars are probably the smallest I'd go. They offer a more predictable ride. The handling is much improved.
I would totally recommend the PST bars if that's you want better handling albeit with a little bit stiffer ride.
Another thing to add to your ride if you want improved handling would be the Hellwig sway bar set. I only have the front bar so far, but I'm thinking of getting the rear as well.
Just so you can keep your options open, check out this...
Firm Feel makes slightly larger torsion bars than the PST bars at 1.06", as well as more than slightly larger ones as well.
Firmfeel Mopar Suspension and Steering
Bergman Auto Kraft supplies Sway-A-Way torsion bars that are 1.08" for the A Body cars.
Bergman Auto Craft - Home of the Modern Muscle Car
Remember... the bigger you go, the stiffer they are and the better shock they will need. KYB's won't cut it and you'll hate the ride quality.
