daves66valiant
68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
Will a 67 B body small block radiator fit my 68 dart with much issue? 22” auto.
The B-Body radiator is taller and will interfere with your hood closing. You may be able to use a flat radiator cap, I have done it in the past, but you have to drill a couple new holes in your radiator support. The only other thing to check is where the inlet and outlet compare to what you have in there now.
