Radiator for 68 dart 340
daves66valiant
68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
SoCal
Will a 67 B body small block radiator fit my 68 dart with much issue? 22” auto.
The B-Body radiator is taller and will interfere with your hood closing. You may be able to use a flat radiator cap, I have done it in the past, but you have to drill a couple new holes in your radiator support. The only other thing to check is where the inlet and outlet compare to what you have in there now.
Thx. If too tall then no bueno.
