Can I leave the top left bolt out?
Yep. Have two that way right now.... but I use the dripperPutting a cam in my 340 and the 4 retainer bolts none have a hole drilled through.
Any suggestions?
Thanks Mike .
Thanks for all the replys, l ended up drilling a bolt. Took 3 drill bits and about 45 min.
What a pain .
and most from the factory didn't even have a bolt with a hole.....You would have been better off drilling a small hole in the retainer plate. The bolt with the hole does nothing.
I haven't put the timing set on yet .
So it would be easy to drill a hole in the plate.
How big of a hole would you recommend?
Thank you sir..040-.060 is plenty big.
My thought is that if I can make it better while I am at this stage, why not.Is it ok to just put it back together the way it was from the factory? Does It not get enough oil stock? Just wondering im gonna be putting mine back together soon.
