My Demon pop out quarter windows don't stay open when driving. I can't see any adjustment on the latch.
Any tricks or ideas to fix this?
They are 73 up windows though so the latch is a bit different.
mine would shut themselves at like 5mph, and that was when they were just 5 years old
They were engineered for kids to pop open and spit their chewing gum out into the street;
The one's on the 73+ cars stay open just fine. I think you need to swap the whole window as a unit though, I don't believe you can just switch the latches. Plus you have to notch the earlier metal sail panels to clear the 73+ mechanisms.
Phillips head screw holds spring tension clip in place. Puts friction on the pivot point which should keep the windows from flopping in the breeze...until 45 years of wear and tear...stuff just doesnt last anymore...
Remove screw and clip, gently reshape clip to put more pressure on the pivot, reinstall.
If you make them too tight then you can't run over and slap them from the outside easy when it stats to rain LOL!
Mine close the second I start rolling in the Demon above 10mph. I thought it was a safety thing. When I was a kid in the 70's, I had to sit in the rear with no AC in my parents 340 Demon.
As my Dad ripped thru the gears they would always close and we were hot. No seat belts, just 2 x 55 mph for cooling.
