dancinwulf
What is the best range of TC for a stock 1971 340 to go with a 727 2200-2500? Or should it
be higher?
be higher?
Call any of the good converter companies. I run a tight Turbo Action 10" S800 and it works great on my street/strip 340. The money I spent on a converter was the best bang for the buck for performance gained.What is the best range of TC for a stock 1971 340 to go with a 727 2200-2500? Or should it
be higher?
I tell you what, it really depends on a bunch of stuff; like'
application,application,and mostly,application,
But also on application,and application,
If you fail to take into account,application,application,
Then in your application, application, may not be a good fit.
Also if your engine is tired or worn out or just never made much low-rpm torque, then any guess is a guess.
Plus if yo have 3.91s or some other HO rear gear, you can get away with less TC..... or vice versa' if
you have hiway gears, the tired 340 might want a lil more TC.
But if your 340 is an animal at low rpm then the TC will depend on other factors, mostly like.....application,and application.
suppose to be 3200. My tach is not accurate and I use an MSD shift light with a 6k pill at the track. Drives like grandma's car on the street until you nail it.I'm curious, where does your S800T flash? I have a S800M..
