I reached out for quotes on the hubs. But, by the time you buy the calipers, rotors, and then have the hubs and caliper adapters machined, it would actually be cheaper to buy a nice radial mount Wilwood caliper, make a radial mount adapter, then use the stock hub/rotor. I think the kit I designed would work well! I just think I can get equal stopping power for less going the Wilwood route.
The machining costs were so high because I was only ordering enough for one kit. I think I could get reasonable quotes on the machining if I was doing a larger production run, but so few seemed interested in it that it would be a big risk for me. Not worth it at this time. For now, I might just keep moving with the Rally Cuda project without a major front brake upgrade and circle back to this later.
