[WANTED] 73 A body qtr window parts
MoparMike1974
Maryland
I need the parts pictured for a 73 A body, specifically a swinger. Im not sure if 74+ are the same because I believe there were some regulator differences in 74, so I included pictures.
I may also need the tracks that bolt on to the bottom of the door window and the roller/bracket on each end of the window.
I have rear quarter glass setup from a 1970 Swinger. I think they are the same. Also have all pieces from my 1972 Swinger in pieces on the shelf if no others can help. Cannot check till Monday after work
Sounds good. It also appears that these rollers may have been used on some B bodies.
