I soaked them overnight in all of that jug of modifier and kept dipping my fingers in it and rubbing it in there one more question what oil should I run and more modifier?As long as you soak the disc before you put them in.
And assemble them correctly and torque them back down, should work great, good luck with it
Ok cool do I have to do the figure 8 thing to break it inI use Lucas for lsd units. If you have popping or jumping on the inside tire in a turn then you need to add more modifier.
Gotcha cool thanks again next is ring n pinion with the sure grip I'm taking that in to get done I'm swapping 2.76 7.25 rear for 3.55 with the 8.75 I hope I'm gonna like it lolYou can or just drive it around some corners.
Driving around the corners allows the clutch packs to open up and let in fluid.
