ValerianMagnum
the little car that could
Hi Guys... I have a 75 440 engine with a forged crank , want to built a 400 hp / 500 torque engine stock....and reliable for cheap *** and i have a 5.9 magnum that i want to convert as a 380 hp crate engine ( had one that did 400+ hp & 440 torque )very easy recipe ,380hp cam and headers....440 as cubic inch but will overeat as i heard because its a bigger engine and the 360 93+ is a roller cam engine with 8:9.1 compression and is 100 pounds lighter but as less torque...the cuda was a 340 4 speed from factory but i will not put a 340 wayyy to expensive for nothing , will be street driven and will be build for this purpose , not a show car, will be a real driver : what do you guys think 440 stock or 360= 380hp crate , around 2-3k for both engines , im on a tight budget.
