240 gordy
How long are the exhaust tips on a 60 340 Swinger, looking for one that will take 2 1/2 exhaust and still look the same as original..
Might try that, thanks..I had a coupla original sets with small inlets, I just chopped the small inlet off at the appropriate size, and welded on the connector size I needed.. just saying..
Thanks, will look into them..slip the new pipe over the original small inlet and mark and cut then weld in new pipe... easy peasy. use a pipe the slips OVER your tailpipe, not inside like factory. Accurate limited sells stainless tips that look factory with a variety of inlet sizes.
Going to do the same thing..I bought mine off ebay 2.5 for about a 100 bucks
