Johnny Dart
WARNING: Be ready for some serious finger hockey to get this thing installed.
Was wanting to know if a 6 blade 18" fan would pull enough air to cool for a future 400hp 360.Mine is a 72 dart. It had a /6 now a 340 with a champion 3 core radiator. I have the new hayden clutch and it gives me a little over a 1/2 inch. I also have a motor mount swap kit not sure what brand. I hope that helps
I guess sometimes ya gotta do what ya gotta do lolWARNING: Be ready for some serious finger hockey to get this thing installed.
I guess it all depends on your radiator. I have a quality engineered products aluminum radiator. With me test fitting the jaguar fan clutch i only have 1/2" clearance from the clutch fins to the back of the radiator. If i went with the heavy duty one it would be even closer.
I started a thread on recommendations on a shroud. I plan on fabricating mine. How far out should the fan blades be on the shroud? I am thinking about half way.
Also i was thinking 1/2" to 3/4" spacing from the blade tips to the shroud, however i dont have have anything to gage this by. Car was a slanty with no radiator in it when i got it. I doubt 67 slanty cars came with fan shrouds anyways. Anybody have a shroud that can give me an idea on what i am looking for dimension wise to build a shroud.
BTW slant 6 cars did have shrouds when they had A/C.
Never had a factory slanty A/C car so i never actually seen onei agree.. infact i used the 6cyl shroud and just flipped it upside down to work with the 360 i just put in.
I have this clutch fan, but need a fan that will fit it. Anybody know an aftermarket or stock fan number I can use. The engine did not come with a fan setup. Running a 408 stroker magnum with l.a. timing cover.Mine is a 72 dart. It had a /6 now a 340 with a champion 3 core radiator. I have the new hayden clutch and it gives me a little over a 1/2 inch. I also have a motor mount swap kit not sure what brand. I hope that helps
What I mean is that the 2747 Hayden is easy....The shorter one is about an inch shorter. Bolts are tough to fit in and thread, nuts over studs require smaller hands with greater dexterity than I have.They install em on jags all the time, why would it be any different?
