j.d.duggan
can I do this by myself? From what I,ve read I spin the pump and turn the motor over slowly.But I thought I read something about spinning the pump at tdc,then turning 90* spinning again,then anouther 90* spinning,and so on and so on till you had turned the engine over 2 full turns.Is this correct?THANKS
