Hi.
Just joined the forum as I just got a new project car in my garage. Just bought myself a Dart 67 convertible.
It does indeed need a fair amount of work.
The plan for the build is roughly
- Install 360 small block, mild upgrade to get some power but still driveable
- Install 727 Automatic
- Install 8.75 rear end
- Install OEM 4-piston disc brakes front
- Install subframe connectors (weld-in)
- Install sway bars front & rear
- Install New Shocks / Springs / Bushings / Ball joints etc.
- Install Bucket seats (OEM).
- Fix the dents and new paint.
- Replace rag top
- Steel wheels with hub caps.
Basically I will collect parts during spring and summer and start working on the car after the summer. (Need to finish my ongoing project car first).
Have been cruising around this forum quite a lot when laying out the plans for this build and will continue doing so as I find a lot of useful info here.
- Replace rag top
