[FOR SALE] new Dynamic converter
Mrpatel
512Dart
Niagara, Ontario
Rating - 0%
0   0   0
I have one brand new in the box, uninstalled 9 1/2" 3200 converter as shown in the attached photos with specs. 727 transmission $600.00 plus shipping.
Thanks Andrew
What is the stall speed of this converter? I cannot make out all the specs. If you could elaborate, I would appreciate.
The spec sheet says 3200lbs. I assumed that was the car weight..It did not say rpm. That is why I wanted clarification
Yep. Not much information. Send the seller a personal message. It doesn't look like he checks in too often.
It also I think says 511 Big chrys... I think that means 511 cubic inch big block chrysler. Not sure but wanted to be clear on that as well.. I f the original poster could elaborate on all the specs, I would appreciate it. It may be just what I need. I have a 512 stroker, solid lifters......
I check in pretty much daily, the converter was built for the car as the spec sheet out lines for mainly street use with a 3200 stall. Never had a drop of transmission fluid in it. Andrew
